typical dodge rust!
Old Jun 18, 2009 | 10:43 PM
young gun's Avatar
Default typical dodge rust!
what easiest andcheapest way to fix the rust, or would it just be better to buy new front quarter panels and some doors and go from there?
Old Jun 19, 2009 | 12:12 AM
94cummins12v's Avatar
sand it down and hit it with primer unless its bad with holes. then its time for a new panel
Old Jun 19, 2009 | 08:40 AM
392hemix's Avatar
buy the replacemt parts form auto body specialys they are the correct gauge, and fit well. They also seem to hold up if you properly instal them. Once you have rust, you will always until its ground out, our cut out. Just puting primer over sanded down rust is going to slow it down, but withing a full winter it will be back bigger and badder.
Old Jun 19, 2009 | 08:56 AM
kazairl's Avatar
Sand most of it down and use a rust converter like Zero Rust or Chassis Saver. DO the backside too if you can. Then paint over it. Problem solved.
Old Jun 19, 2009 | 10:07 AM
outlaw1_gt's Avatar
i sanded mine down. patched holes in front quarters and two toned truck with rhino line
Old Jun 19, 2009 | 10:08 AM
the best why to do it is sand most of the rust down the pray it with phosphoric acid. the acid neutralizes the rust and keeps it from spreading then paint over it
Old Jun 19, 2009 | 11:39 AM
stkdram55's Avatar
i have to do this with my truck, im gonna cut the rust out of door and patch it then either duraglass or bondo then either paint it or rhino line the bottom
Old Jun 19, 2009 | 11:43 AM
Jazz's Avatar
Zinc chromate is also a good rust converter and inhibitor
Old Jun 19, 2009 | 12:25 PM
outlaw1_gt's Avatar
rhino looks good get a good quality or it will fade or scratch
Old Jun 19, 2009 | 01:19 PM
A couple of options for you
If the metal isnt completely rusted through -
Rust Bullet - Rust Inhibitor Coating & Products Rust Paint & Preventative
I know there are other brands like POR15 etc.
If its is completely rusted through:
New panels: LMC Truck Parts: Chevy Chevrolet Blazer S10 GMC Jimmy S15 Ford Bronco Ranger Pickup Pick Up Accessories/Catalogs
