HELP!
Old Jun 16, 2009 | 11:58 PM
WyoD-MAX's Avatar
Default HELP!
alright after going through all the hell of installing my new toys off of the wrecked truck im still struggling to get her running... turns out the bd turbo seized up gonna get that fixed... anyways i ended up with a aurora 5000 from ats well basing my installl with the bd i went and installed the oil feed first and pulled the ing fuse to pump oil through the line well where i have it installed is where bd recommended with their turbo ( bigger feed line diameter less pressue) so i got online and looked up ats install and doesn't clearly say where to install just says oil line and has a picture of the stock port in the middle of the block? is this correct? do i just use the supplied fitting and slaap her toegether... but also instructions say something about using the stock banjo bolt and crush washers????? where would you need to install those if you just put the fitting and line in that port??? any help would be appreciated ......
Old Jun 17, 2009 | 07:19 AM
Whit's Avatar
Site Mascot
call BD and get clarification so its done right, you spent alot of coin with them, they will help ya
Old Jun 17, 2009 | 07:09 PM
Eric @ ATS's Avatar
How old is your A5K kit?
