Engine Oil
Old Jun 16, 2009 | 06:58 PM
bowtech's Avatar
Default Engine Oil
is there a certain oil you use that helps with the ol 12 valve. What about additives to the engin oil to help?
Old Jun 16, 2009 | 07:04 PM
mysterync's Avatar
Just run valv. blue 15w40! Best on the market by far , Unless looking in synthetics. As far as off the shelf oil's It's show the best results and oil analysis
Old Jun 16, 2009 | 08:06 PM
sidekick's Avatar
been happy with rottila t but changed over to amsoil picked up a few mpg waiting on the remote dual filter kit to come in
Old Jun 16, 2009 | 08:10 PM
392hemix's Avatar
i second the rotela t, i run that with a qt of lucas and i also use a k&n oil filter
Old Jun 16, 2009 | 09:11 PM
kbailey's Avatar
until I get the random oil leaks .. err I mean the "rust protection system" under control I'll stick with Delo or Delvac. When I ran Rotella there was always a funky smell so I had to switch .. other than that no complaints. The dual bypass kits from AMS are amazing and I highly recommend them. Schaeffers is also an excellent synthetic oil to consider.
Old Jun 16, 2009 | 09:17 PM
mysterync's Avatar
I'm not trying to offend anyone, But Rottella is considered one of the worst oils to alot of folks. Most of your shops wont run it. DO NOT RUN AN OIL STABALIZER LIKE LUCAS. Your oil, If a good quality name brand lubricant should never need an additive! I've seen more harm done with additive like that than good! Again, before using rotella please do some research so you can make an informed decision regarding the well being of your engine.
Also, Saw a note about a K&N filter. I've seen issues there as well. The absolute best filter on the market for these trucks is the Fleetguard filters (Also Sold as Mopars). I suggest doing some research on this area as well!
Old Jun 16, 2009 | 09:31 PM
392hemix's Avatar
really......?
94 12valve's Avatar
what about zinc additive?
Old Jun 16, 2009 | 09:39 PM
392hemix's Avatar
what harm do you see running lucas? i need to know....Not being a dick...Just curious. Also what oil analysis did that come from? Whats the best synthetic oil to use in your opinion? Moblie one delvac ok to use?....
Old Jun 16, 2009 | 09:57 PM
94cummins12v's Avatar
im usiing the valvaline extreme blue full synthetic 5w-40 endorsed by cummins in my truck
