New Smarty on my 6.7L .
Old Jun 15, 2009 | 09:34 AM
6narowbuilt2tow's Avatar
Default New Smarty on my 6.7L .
Saturday i installed the smarty s67 on my 07.5 dually along with the 5 inch turbo back exhaust.And it sounds and runs a hole lot better. It will haul *** now untill 2200 Rpm's. thats when the clutch slips yeah thats right slips the clutch in 1st. Through 6th. But untill then it will haul ***. and smoke like my old 5.9 !
Old Jun 15, 2009 | 10:52 AM
Sounds like its time for a Valair DD Clutch
Old Jun 15, 2009 | 11:50 AM
dodgeram082500's Avatar
I know im also needing a new clutch
Old Jun 15, 2009 | 01:03 PM
GMB's Avatar
GMB
Hi 6narowbuilt2tow,
did you also defeat the EGR or just DPF?
Thanks,
Old Jun 16, 2009 | 08:23 AM
DslDeamon's Avatar
yeah im about due for a new clutch also stock power and only 19k on it
Old Jun 16, 2009 | 12:19 PM
FarmDiesel's Avatar
Ive only killed the DPF so far myself. My dealership let that slide, dunno if theyll let the EGR slide though so im waiting
Old Jun 16, 2009 | 12:32 PM
GMB's Avatar
GMB
I thought your had to delete both the DPF and EGR at the same time when running the Smarty. How did you delete just the DPF? Did you just unplug the EGR electrical connector?
The reason I ask is I will install my exhaust tonight while I still wait for the EGR and cooler delete to show up.
Old Jun 16, 2009 | 03:30 PM
IT depends on what you are going to run I ran ME11 with the egr and dpf turned on with no problems, or if you run the regular smarty software you will not have a problem. I deleted mine a couple weeks after running it so I could turn the 4th injection cycle off
Old Jun 16, 2009 | 05:59 PM
GMB's Avatar
GMB
I am confused I think. I am running the Smarty currently with both the EGR and DPF in place. Everything is great
6narowbuilt2tow said "Saturday i installed the smarty s67 on my 07.5 dually along with the 5 inch turbo back exhaust"
I read that as he deleted the DPF with just the smarty and left the EGR in place (probably me assuming wayyyy to much).
From what I have been reading - with the Smarty 6.7ME you have to defeat both to work right?
Am I over thinking this? Can you run the Smarty 6.7 (any configuration) and leave the EGR in place but the DPF deleted?
Thanks for your clarification. I am glad I joined this forum.
Old Jun 16, 2009 | 11:08 PM
Ok here what I did I called the smarty hotline one day to ask if it was ok to run the ME software with the egr intact he said yet but on the dpf/egr off option on untill i deleted the egr
