gauge install
Old Jun 15, 2009 | 01:54 AM
jesse's Avatar
Default gauge install
Which wire do I tap into for the dimmer switch and what should I use in my fuel pressure gauge?
Old Jun 15, 2009 | 02:30 AM
coyropin's Avatar
there is a fuse i think it number 9 or 11 i will go out and looky here in a min, by your door panel
Old Jun 15, 2009 | 10:12 AM
jesse's Avatar
Where is the boost bolt supposed to go? I had it in one of the bolts right next to the valve cover but wasn't making any boost at all. I know that the tube isn't kinked because when I blow into it I can get the needle to move.
Old Jun 15, 2009 | 10:32 AM
SeaDrive's Avatar
Here is a pic from Diesel Manor's website for the boost bolt:
http://www.dieselmanor.com/diy/CMS3-...stBolt1-lg.jpg
Old Jun 15, 2009 | 01:46 PM
jesse's Avatar
Ok thats the exact spot I have mine in and its not even lifting the needle a tiny bit. Could I possibly be leaking all of my boost somewhere?
Nevermind. I wasn't putting enough load on the engine.
With my wiring I'd rather tap in right behind the headlight switch rather than tapping into a fuse so I was wondering which color or number wire goes out to the dash.
Also with the fuel pressure gauge is it ok if there are some air bubbles in the water side? Should I try to put some antifreeze in the gauge itself or will filling the isolator and the tube be enough.
huntman7
Sep 4, 2015 04:49 AM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
450r racer
Nov 14, 2014 05:11 PM
scottxmorris
Oct 8, 2014 02:14 PM
