Covered in grease, need quick answer Pleeeeeeease...
Old Jun 15, 2009 | 01:35 AM
Renteria1217's Avatar
Default Covered in grease, need quick answer Pleeeeeeease...
I just put new upper and lower ball joint on and now the damn brake caliper won't go back on. The brake must have been pushed while it was off. So what is an easy way to get the caliper to open back up so I can get it???
Old Jun 15, 2009 | 01:40 AM
jesse's Avatar
I use a big c-clamp to push the caliper back in. I don't know what else you could use if you don't have a c-clamp big enough. If you just did ball joints I imagine you have something large enough to have pressed them in with.
Old Jun 15, 2009 | 01:42 AM
Oh yeah...I might be able to use the ball joint press. It's kind of a big c clamp.
Sweet thanks. I'll give it a shot real quick.
Old Jun 15, 2009 | 01:55 AM
Uncle Bubba's Avatar
Pull the cap off the brake reservoir to relieve the pressure and it should push back in pretty easy.
Old Jun 15, 2009 | 02:12 AM
I got it. Used the ball joint puller. Still works bent!
or ball joint press rather
Last edited by Renteria1217; Jun 15, 2009 at 02:12 AM. Reason: Automerged Doublepost
Old Jun 16, 2009 | 05:04 PM
Whit's Avatar
Site Mascot
when you do this ya should use the bleeder screw on the caliper itself rather than pushing the oil back into the resivor
Old Jun 16, 2009 | 06:48 PM
mysterync's Avatar
Tighten the bleeder screw before removing clamp
Old Jun 17, 2009 | 03:23 PM
I already got it, hope I didn't f*ck anything up doing it that way. Breaks still work though. Thanks everyone.
Old Jun 17, 2009 | 09:07 PM
Mopar1973Man's Avatar
Me... I would just use a large screwdriver and light pry the pistons back.
Or...
The C-clamp idea is really common.
As for pushing the fluid back to the MC I can't see the harm in it being the fluid naturally returns to the MC after you release the brake pedal every time.
Old Jun 17, 2009 | 09:22 PM
cruiserfj45's Avatar
I have ruined 2 master cyls by not opening the bleeder screw. I know it had something to do with pushing too much fluid back too fast. I don't run into problems when I go slow.
