2 questions
Old Jun 14, 2009 | 09:42 PM
94dizzyram's Avatar
Default 2 questions
What should the truck in my sig be idling at and how high should my egts be. Truck idles at 7 or 8 hundred rpm and egts are between 6 and 8 hundred cruising at 55 to 60. Thanks
Old Jun 15, 2009 | 04:01 AM
98whitelightnin's Avatar
Those sound like the right numbers to me.
Old Jun 15, 2009 | 04:16 AM
coyropin's Avatar
im running the same 700 rpm, and flat road 65 im around 800 egt
Old Jun 15, 2009 | 01:31 PM
Captn_tyler's Avatar
Same as my truck
Old Jun 15, 2009 | 01:40 PM
biged681985's Avatar
both are where they should be imo
Old Jun 15, 2009 | 02:09 PM
jkidd's Avatar
sounds good to me.
Old Jun 15, 2009 | 04:37 PM
cumminsman65's Avatar
Bout the same as mines runnin
Old Jun 15, 2009 | 05:29 PM
94dizzyram's Avatar
thanks, the numbers sounded kind of high to me but if that is what everyone is running then i guess its normal. thanks again
Old Jun 15, 2009 | 05:36 PM
You cant really adjust idle on a 24V anyway - unless you have some sort of adjustable high idle switch.
Old Jun 15, 2009 | 07:02 PM
turbo20psi's Avatar
running the same here to You can check the actual reading by a OBD2 scanner it will tell the true rpms.
Mar 20, 2015 08:20 AM
VanGuy
Feb 3, 2015 12:19 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
