can u drill out the injector connector tube
Old Jun 14, 2009 | 04:29 PM
scooter's Avatar
Default can u drill out the injector connector tube
can u drill out the injector connector tube and if so wat size and will it hurt anything
Old Jun 14, 2009 | 04:35 PM
ToolManTimTaylor's Avatar
Yeah anything is possible with the RIGHT equipment (0.93 is the largest) The line sizeto the connector tubes needs to be bigger first, A:. B serious Air, Fuel, and Valve duration is needed for support thereafter. Even then the motor should be built to support what fuel you are intending to put into it is done right to support that.
Old Jun 14, 2009 | 06:27 PM
mysterync's Avatar
It's much cheaper and easier just to buy a set. Economically priced with less leaks
Old Jun 14, 2009 | 09:35 PM
If the holes you drill out aren't exactly the same your going to have issues.
Old Jun 15, 2009 | 08:48 AM
mysterync's Avatar
Moreso, You cant ever drill them straight which leeds to big problems at the junction between the fuel line and the connector tube.....
Old Jun 15, 2009 | 10:06 PM
Bosshogg's Avatar
I was told if you stick them in a lathe you can drill them out. .120 max
Old Jun 18, 2009 | 08:47 AM
Mopar1973Man's Avatar
I agreed...
The only thing oversized lines tend to do on a mild bomb truck is make it lopey at idle. The larger the lines the more lopey it gets..
