exteem fuel pressure
Old Jun 13, 2009 | 12:08 PM
cummins army's Avatar
Default exteem fuel pressure
ok i just noticed today while driving my fuel pressure is at 76psi what the hell i used to sit at 18 at idle now even at wot its 76 i think the guage is a little messed up because i dont think the air dog 150 can even put out that much pressure. i will say this much it drove the same and no problems i just also got to wait till monday till quadzilla opens to see what they say about this on the scout module so i just want to see the numbers come back to normal. any ideas and thoughts
Old Jun 13, 2009 | 12:20 PM
mysterync's Avatar
Bad gauge
Old Jun 13, 2009 | 12:35 PM
Originally Posted by mysterync
Bad gauge
you say bad guage but its a didgital monitor like the edge juice with additude
Old Jun 13, 2009 | 01:11 PM
Mr.Krabs's Avatar
If you had that much pressure it would blast the top off of your filter housing.
Put a different gauge on it if you want to know what the real pressure is.
Old Jun 13, 2009 | 01:51 PM
mysterync's Avatar
My bad, Bad sender
Could be a ground or a sensor wire
Old Jun 13, 2009 | 03:36 PM
with the air dog 150 you dont use the stock filter housing you use the filters that come with the air dog and bypass all factory fuel lines and everything
Old Jun 16, 2009 | 05:16 PM
Whit's Avatar
Site Mascot
My bad, Bad sender
X2
Old Jun 16, 2009 | 06:25 PM
crazycooter's Avatar
The air dog is only good for pressures up to the mid 20's psi. I think it would have to be your sender unit or your gauge.
Old Jun 16, 2009 | 06:41 PM
mysterync's Avatar
Airdog's wont even go in the 20lb range. All airdogs are low pressure setups. Air cannot be removed under high pressure!
Old Jun 17, 2009 | 03:45 PM
Mr.Krabs's Avatar
Ahh,my bad,when I installed one in Ma's truck I just ran it into the filter housing,since I run Canada a lot in the winter (gelled fuel is a beeeatch!)
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
