trany problem
hey all, I POSTED IN THE WRONG AREA. i have a 98 4x4 AUTO THAT IS JUMPING BACK AND FORTH BETWEEN OD AND THIRD AT ABOUT 45MPH AND 3RD AND 2ND AT ABOUT 35 WITH OD TURNED OFF IJUST HAD A FLUSH AND HAVE NEVER ADJUSTED THE BANDS IS THE TRANY A BIG DOOR STOP OR CAN I DO SOMETHING WITH IT
make sure all grounds are clean and tight.
how old are the batteries?
this is a very commom problem that can often be a simple fix. the DTT noise filter does wonders too.
check the easy stuff first, grounds and batteries!
If you are getting shifts from 3rd the 2nd it's probably more than a noise issue. Most likely, when they flushed the trans, they did it in. It's probably loaded the VB with tons of crap.
Sounds more like a gov solenoid issue to me, but if it's only TC cycling, the DTT noise filter will fix it.
Obviously, you need to be sure the batteries are in good shape, clean all the grounds.
Dave
Dave
Need to call them to order it.
