my first 12 valve
bought my first 12 valve. its got bigger turbo, 4" turbo back exhaust injectors, not sure what ones or size. and the banks twint ram intake.but my plans are 370 marine injectors. #6 plate. 4K GSK FASS 180 gph. what yall think? i got a 24 valve but dont know 2 much a bout 12 valves. ill post pics.
Do you need new injectors? If not I would try and find out from the previous owner what they were instead of buying new ones if they are not needed. Remember, with the 4K GSK you will need 60lb valve springs. If you do not have gauges already, get a set of them before ANYTHING, Unless you like buying expensive parts multiple times.... The FASS is a good idea but you will not need more than 150gph. What size/make is the turbo?
got the number of the guy who built it. its got a HX40 turbo an 90 HP injectors
Last edited by skyjacked84; Jun 13, 2009 at 12:03 AM. Reason: Automerged Doublepost
x2
it sounds like its already set up pretty well and the person that did it knew a thing or two. Does it still have the stock plate in it? Seems like someone that already put a turbo and injectors on it would have fueled it up quite a bit.
bonestock
Feb 1, 2015 08:41 PM
