no start when hot maybe ???
Old Jun 11, 2009 | 09:02 PM
maxamil's Avatar
Default no start when hot maybe ???
94 stock auto 4x4 does not want to start when hot , sometimes .most of the time it will . but if your 50 miles from home and have to be back asap your sol . sit for an hour or so and boom . it will take right off first flip????? i have switched relays ,flipped start solenoid ,swore ,only thing i have found that works is let it cool . its getting warmer outside not wanting to drive it . take your best guess i am out of ideas
Old Jun 11, 2009 | 09:12 PM
Beets's Avatar
next time it dose it leave the Key on after you try to crank it,( that is if it will crank) open the hood and see if you fuel shut off is in the up position. if not push it up by hand and try again, if it works then your Shutoff may be bad. Magnetic coils sometimes only act up when they are hot.
Old Jun 11, 2009 | 10:13 PM
maxamil's Avatar
Beets i checked that ,its working. also cleaned all battery ends and grounds. still does it, but what has me is it doesnt do it all the time. cranks over realy fast,no start no smoke ,nothing not even a flutter.let it cool and start first flip????no stumble or anything
Old Jun 12, 2009 | 07:03 PM
daveO's Avatar
Same exact thing happened to me. Turned out to be the starter. I ordered the Larry B starter contacts and rebuilt my starter, no more problems. As a temp fix, mine would start if I climbed under and tapped the starter with something like a (insert tool of your choice to act as a hammer).
Old Jun 12, 2009 | 08:20 PM
vlado's Avatar
my friend had same starting issue but on nissan gasser and only would not start sometimes and only when hot.over winter it never acted up.we found that his ignition key had some kind of chip in it and was messing it up.he took spare key and it has been almost year no problem.if you have any security system i would try to disconect that to make sure good luck with your problem
Old Jun 13, 2009 | 02:33 PM
Beets's Avatar
he said the starter would crank the Engine really fast. so the starter is working.
Old Jun 13, 2009 | 08:24 PM
daveO's Avatar
Sorry, missed that part.
Old Jun 22, 2009 | 07:15 PM
maxamil's Avatar
hey guys and gals it did it again today . what the heck is wrong with this thing . drove to work 58 miles turn it off try restart . starts first flip drive home 58 miles turn it off try restart cranks real fast no start . eat supper go back out turn key wait to start light goes out engage starter first flip its running sorry about being long since last post ,honey doooos
Accubuck
May 7, 2015 04:46 PM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Feb 22, 2015 09:07 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
powerstroke74
8
Oct 29, 2014 05:40 PM
