crap! what should i do
Old Jun 11, 2009 | 03:11 PM
c0zgrove's Avatar
Angry crap! what should i do
ok guys i need some help i took my fuel plate out the other day just dickin around well i went to put back in today and one of the bolts had the threads from my pump on it when i took it out its the bolt closest to the cab on the fuel shut off side what do you guy think i should do cuz now i only have two bolts holding my afc on thanks for any help
Old Jun 11, 2009 | 03:33 PM
cummins95's Avatar
pull out one of the other bolts n go to the hardware store
oh wait didnt completely read before i answered, i've heard that 3 is enough to hold it if u replace the break off screw you should be alright
Old Jun 11, 2009 | 04:03 PM
12valvetater's Avatar
helicoil it
Old Jun 11, 2009 | 04:11 PM
c0zgrove's Avatar
well i got out there again and pulled the afc and took the other bolt and slowly screwed it in that hole i think just the top half of the threads are gone so i think i can make it work what do yall think would i be enough threads
Old Jun 11, 2009 | 10:56 PM
94cummins12v's Avatar
i drilled all mine out at taped them with a 1/4-20 tap then used 1 1/2 long stainless steel pan head bolts to put mine on with just got to try not to get shavings in the pump
