rv275
They add an extra 30-40hp to the rear wheels when all is said and done. Best bang for the buck injectors out there if you just want to play on the street and don't need a serious power house.
If the rest of your truck is stock which it looks like it is then the RV275's are as big as you wanna go. With the EZ and these sticks your gonna be maxxin out the tranny and heat will quickly become an issue.
If your gonna start playin like this you have to have an exhaust, air intake, high pressure lift pump and FUEL PRESSURE GAUGE VISIBLE AT ALL TIMES and not necessarily in this order.
well its stock know for the most part. i have stock 3inch straight pipe into a 5 1/2 in stack. and getting a 4 inch soon. have a k&n filter wirth stock box cut open bigger. the intake elbow is ported bigger and smother with the inside polished. and have a 130 gal per hour lift pump with 1/2 lines 98% of the way with a column mounted fuel pressure gage. working on tranny but i just love the power of my dads truck and he only has 150 injectors with tranny, pully driven lift pump and adrenalin. on stock air box ported stock elbow. and 4 inch.
It all sounds good except the K&N stock filter replacement. I do like K&N but only the Canon Style full replacement filter. It's not uncommon at all to suck those stock replacement filters into the intake and turbo.
Fill out your signature so we know what ya got.
