Carbon in the EGR valve
Old Jun 10, 2009 | 11:38 AM
ZAWE74's Avatar
Default Carbon in the EGR valve
What causes the carbon buildup in the egr valve and when it sticks, why doesn't it show up in the dtc? The egr cooler seems to be ok. Would just driving in town do it and not getting on the highway very much?
Thanks, Zane
Old Jun 10, 2009 | 12:30 PM
mysterync's Avatar
In town driving is a major cause but excessive emmisions will also cause it. I would contact a local BG Rep and find a shop in your area! To date there company is the only producer of a EGR service for the 6.0L PSD!
Old Jun 10, 2009 | 07:22 PM
hock6.0's Avatar
i take my egr valve out and clean it about once a month. with some good cleaner. it helps and it don't take long to do.
Old Jun 15, 2009 | 11:29 PM
BLACK_06POWERSTROKE's Avatar
^^what he said
Old Jun 16, 2009 | 06:52 AM
Diesel Powered Rocket's Avatar
Before I got the SCT X3 tunes, I would take the valve out and clean it. It only takes 30 - 45 minutes.
Now that I have custom tunes I had them turn it off and its not been a problem.
Old Jun 28, 2009 | 03:04 PM
Black 6.0's Avatar
What symptoms will be noticed if EGR is getting carboned?
Thanks,
Black 6.0
Old Jun 29, 2009 | 11:16 AM
Diverdan's Avatar
I had my truck at the local dealer and they told me I needed to replace my EGR valve. I am pretty handy with a wrench and want to do it myself. It seems with what I have read, it would be recommended to pull it and clean it first. Any suggestions? Also, they said I needed to replace my EBP sensor as well. Any suggestions or advice would be greatly appreciated.
Old Jun 29, 2009 | 01:31 PM
whattruck's Avatar
It used to be a Ford service policy that if the valve was 50% clogged they would replace.
Since then a service update says to clean and replace o-rings.
But it is quicker and has more profit to replace. So they will just replace.
I clean mine at the oil change. Replaced the o-rings every other cleaning.
Just don't let the solvent get into top part.
Old Jun 29, 2009 | 02:15 PM
ltr450's Avatar
just unplug it
Old Jul 6, 2009 | 05:30 PM
conner's Avatar
Will it throw a code if you keep it unplugged ltr450? I also read somewhere that a guy did that with his icp too? I would try it my self buy my rig is currently being used as a yard trophy
