usin two stroke oil
Old Jun 9, 2009 | 11:00 PM
bowtech's Avatar
Default usin two stroke oil
Any one have problems with seals and stuff startin to leak? any bad things happen? i use to race motorcross and we have alot of pre mix for dirt bikes (my lil bros i had a four stoke) will that work?
no one uses two stroke pre mix when they fill up any more?
Old Jun 9, 2009 | 11:45 PM
I run 2 stroke. No problems yet...keeps the barrels and plungers lubed.
I know that ULSD has lube put back in...but I still dont feel good running without an additive. I sometimes run a gallon of used oil in the summertime (on my 12V only)
Old Jun 10, 2009 | 10:40 PM
Raking79's Avatar
I use a quart of tranny fluid as an additive in the fuel during a fill up or sometimes Lucas fuel additive about every 4 fill ups.
Old Jun 10, 2009 | 10:45 PM
ATF isnt the best idea.
Old Jun 10, 2009 | 11:09 PM
wildbill's Avatar
It's expensive, but I've been running hydraulic oil the last couple months. So far so good.
Old Jun 10, 2009 | 11:30 PM
bowtech's Avatar
wat are the best oils to use? are there any that would actually help break up deposits and build up?
Old Jun 10, 2009 | 11:53 PM
wildbill's Avatar
It's not so much for abating carbon buildup, but more for lubricity. 2 stroke oil has petrolium distillates in it to help with carbon build up. But be careful, don't run anything with alcohol in it.
Old Jun 11, 2009 | 02:08 AM
94cummins12v's Avatar
if you want to decrease carbon get water/meth the best addatives are to clean the injectors or lube everything up
Old Jun 11, 2009 | 03:39 PM
bowtech's Avatar
yeah i no the oil is just to lube. yeah brandon i posted on that forum about the meth and water that you sent him a pm i asked you to send it to me to
Old Jun 11, 2009 | 09:04 PM
Beets's Avatar
the friction additives in atf can COULD cause problems in the long run. i dont do it. because of this and no one has do any long term testing on it to see the effects. but i have been told By a person who helped design the 12v and 24v if you have a vp44 going bad put a quart of atf in it and order a new pump. so i guess it COULD lube it for a lil.
