trans temp probe location
Old Jun 8, 2009 | 03:15 PM
twodogz's Avatar
Default trans temp probe location
can a guy put the trans temp probe in the return line from the cooler just before it enters the trans housing and would it read simalar temps.to having it in the pan i dont want to drill the pan and i dont want it in the outlet line to the cooler thx
Old Jun 8, 2009 | 06:53 PM
BigDiesel359's Avatar
The going from the cooler back into the trans? You do NOT want your temp probe there, that is where your fluid is going to be the coolest and you will get false readings. For the best results you will need to put it in your pan or on the line going from the trans. to the cooler.
Old Jun 8, 2009 | 08:22 PM
Yup - needs to be in the hot line.
Old Jun 9, 2009 | 12:25 AM
twodogz's Avatar
ive heard pros and cons of installing it in the hot line.i know it would read the temp.right away after leaving the trans. but thats right after coming out of the tq. con. and as soon as the conv. unlocks, the temps. will always skyrocket regardless of the conditions the truck is running under whereas putting it in the pan tells you the temp. that the main body and parts of the trans. actually sees.thats what somebody at pdr told me.i will be pulling a 13,000 lb. 5er occaisionally if that matters.[no racing or sledding] thx
Old Jun 9, 2009 | 09:42 AM
What would be interesting is getting a digital temp guage and two senders - one in the pan and one in the hot line with a switch between the senders. Then you can see the difference.
Jake9473
Jul 22, 2018 08:19 AM
Aug 13, 2015 10:10 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
casper83
23
Jul 27, 2015 01:53 PM
doodieroot
May 10, 2015 11:48 PM
