A/C Problems
Old Jun 8, 2009 | 12:01 AM
Fiveseven's Avatar
Default A/C Problems
I have a problem with my a/c when I make a sudden stop or sudden acceleration and I have the a/c cold it will start blowing hot air I am having to turn it off and back on to get to strat again. Has any body else had this problem?
Old Jun 10, 2009 | 11:37 PM
wildbill's Avatar
When was the last time you had the system serviced??
Old Jun 12, 2009 | 10:52 AM
dukeboy_318's Avatar
sounds like a vaccum problem. there is a door flap that controls how much heated air or cooled is put out through the air ducts, to me it sounds like when you use your brakes, your vaccum is dropping too much and causing the door to swing towards the hot side. you need to check and make sure the line is connected at the vaccum pump, if that doesnt work, you may try testing the vaccum output of the pump.
Old Jun 12, 2009 | 09:33 PM
Mopar1973Man's Avatar
I agree... When did you last check the freon in the system?
Old Aug 14, 2010 | 03:20 PM
Sparky05's Avatar
I am having the same problem let me know what you find out it's driving me nutts.
Old Aug 14, 2010 | 09:44 PM
voidswarranty's Avatar
make sure ur condenser is clean and check ur freon carge and checking the vaccum is a good idea to good luck
Old Aug 18, 2010 | 10:12 PM
stevenbrazell's Avatar
ac condensor fan took a dump on you. same thing happened to me. let your truck idle, and turn the ac on. the fan should kick on, if it doesnt, time to replace or install a electric fan like i did.
when you start to move, air flows through the ac radiator and lets it cool. when you stop no air is moving. thermodynamics. or try watering down the radiator with a garden hose. it should cool it down real fast.
Old Aug 19, 2010 | 05:59 AM
puddlepirate's Avatar
with your truck at idle can you hear the a/c clutch clicking in and out? If so your most likely low on refrigerant. If the clutch is staying engaged, I'd say trouble shoot IAW the posts above. Does it seem to matter if your on max a/c or not?
Maclain Marsh
Jul 13, 2015 06:23 PM
CumminsCoalRoller24/7
May 5, 2015 08:55 PM
Zachbishop
Feb 10, 2015 10:23 AM
ChgoSquad5
Ford Powerstroke 2011-Up 6.7L
Jan 6, 2015 11:37 PM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
