high idle
Old Jun 7, 2009 | 08:45 AM
dan33klein's Avatar
Default high idle
hey guys i know its summer and i shouldnt be worrying about high idle but i wanna get some ideas to rig one up on my 96 12 valve.
i was thinking like a pto cable or something? i know has done it before so post your ideas!
thanks
Old Jun 7, 2009 | 02:15 PM
BigDiesel359's Avatar
All of our firetrucks have a cable on a threaded ****, turn it out you raise your RPMs, turn it all the way in and you have normal pedal operation. This of course makes it possible to run the needed pumps at the needed RPM on the truck when not on the road.
Old Jun 7, 2009 | 05:02 PM
94cummins12v's Avatar
thats actually not a bad idea
Old Jun 7, 2009 | 05:26 PM
Great time to work on it now. I was working on one last fall, but it got cold and I dont have a garage large enough for my truck so it never got finished.
Some guys have tried a solenoid off of a carburator but most have had limited success with that.
Im thinking a PTO cable would work. I was messing around with a choke cable but dont want to drill a hole in the dash unless absolutely necessary.
Old Jun 7, 2009 | 05:29 PM
since my cruise comtrol dont work im going to use that cable for mine
Old Jun 7, 2009 | 06:23 PM
wisconsin redneck's Avatar
i think of doin this... nybody got some pics??
Old Jun 7, 2009 | 08:11 PM
95 12 valver's Avatar
i ran a wrecker for many years one being a 96 cummins and it had a simular set up to the fire engine with the cable on a crank. except the crank had a spring loaded ratchet so you could push a center a release button on the **** and it brings it back down to idle. the place that built them tow trucks is still in buisness i'll see if i can get a part # or even a manfacture name off them.
Old Jun 7, 2009 | 08:16 PM
I think thats like the PTO cable that I was mentioning. Was it like this?:
PTO Cable - 10' - Mfg# R04D4.5X10
Cables, Push-Pull, PTO -- Midwest Control Products Corp.
*This One* - http://www.sandstruck.com/catalog/PTO/cableassem1.htm
Old Jun 7, 2009 | 08:19 PM
PTO Cable - 10' - Mfg# R04D4.5X10 that would work wonder if there was a way to set it up so that it stays at a constat length for a certain idle. im sure the return spring on the pump will cause that cable to retract, if it doesnt have a lock
Old Jun 7, 2009 | 08:21 PM
Look at the last link - I think thats the ticket - a Vernier PTO cable. You can adjust it to where you want and then hit the button to release it.
