de-lip, open piston bowl?
Old Jun 6, 2009 | 02:32 PM
mech2161's Avatar
Default de-lip, open piston bowl?
I'm in the process of doing a conversion. When I pulled the head to have it 0-ringed I found a cylinder that had some piston damage. I need to replace it and wondered if I should pull them all and open the piston bowl. I'm doing full cuts, 5X22's. 5k GSK, MAX SPOOL 2.5 cam and mild head port. Is this a good idea or not? If so how much should they be cut before their rounded? Anyone have a picture of one that's done?
Old Jun 6, 2009 | 05:51 PM
94cummins12v's Avatar
why would you want to cut the pistons i have everything you just explained and i have oversided pistons that have the same bowl as the stock ones
Old Jun 6, 2009 | 06:54 PM
mech2161's Avatar
Opening the bowl will keep the fuel off the top of the piston with advanced timing.
Old Jun 7, 2009 | 05:04 PM
or you can experiament with different injector washers and that will do it also
Colbyflory
Aug 16, 2021 09:19 AM
Strictly Diesel
Strictly Diesel
Sep 17, 2015 05:11 PM
Feb 3, 2015 01:10 PM
Jan 8, 2015 03:00 AM
