47re Trans mount torque spec help...
Old Jun 5, 2009 | 01:32 PM
hereismylife's Avatar
Default 47re Trans mount torque spec help...
I searched this and found it very hard to find the spec for the trans torque spec.
I am looking for the torque spec for the
1. trans mount to trans.
2. trans mount to cross member.
thanks
Old Jun 7, 2009 | 12:53 PM
MRaynor's Avatar
Old Jun 9, 2009 | 11:35 PM
how did I confuse you?
Old Jun 10, 2009 | 09:40 AM
mysterync's Avatar
Rear Mount - Support Cushion-to-Crossmember Nut 35 ft.lb
Rear Mount - Support Cushion-to-Support Bracket Nuts 35 ft.lb
Rear Mount - Support Bracket-to-Transmission Bolts 75 ft.lb
Transmission Support Bracket - (2wd) Bolts 50 ft.lb
Transmission Support Spacer - (4wd) Bolts 50 ft.lb
Transmission Support Spacer-to-Insulator Mounting Plate - (4wd) Bolts 150 ft.lb
Old Jun 11, 2009 | 11:07 AM
thanks
Old Jun 11, 2009 | 11:41 AM
mysterync's Avatar
Anytime Bud!
Nu2cummins
Jun 26, 2015 02:30 PM
