04 diesel not running right
Old Jun 4, 2009 | 03:50 PM
double d 1's Avatar
Default 04 diesel not running right
ok here is the deal. friend has a 04 powerstroke. going up a hill it was blowing alot of black smoke towing no load. this just started. i rode with him today after cleaning the egr valve and it seemed to do it on level ground slowly accelerating like it was missing every 1 to 2 seconds and when it had a miss a little black smoke came out. he took it to a mech. shop and the scanner said no codes. he also said he had the oil changed awhile back and it is an 1/8 of inch over full,1/4 at the most. do these trucks if a injector is bad leak oil into the transcase like a early model chevy does? are the injectors in side the head or are they external. ant help would be great. what does a bad egr valve do? thanks
Old Jun 4, 2009 | 06:39 PM
ltr450's Avatar
smell the oil to see if it smell like fuel. as far as the egr valve just unplug it and forget about it.
Old Jun 6, 2009 | 12:02 PM
Superstroker10's Avatar
yes if an injector goes bad they can leak fuel into the crankcase.
put some oil from the dip stick on a piece of cardboard and watch it. the oil will no spread out like the diesel will.
Old Jun 8, 2009 | 09:27 PM
walkman's Avatar
a power balance test is best when cold but if the oil is over full u got an injector problem sometimes a balloon test on each head is the only way to narrow it down then dye has to be added and the valve covers removed
Old Jun 10, 2009 | 10:59 AM
cedarheaven's Avatar
-I have a 96 Powerstoke which got a big glp of water. I have done everything to bleed the system but still won't run...any help out there!
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Mar 18, 2015 07:30 PM
JamesL91
Mar 15, 2015 06:11 PM
wolfnexus
Nov 4, 2014 10:04 PM
