Single Stack Tips and install pics
Old Jun 4, 2009 | 07:11 AM
jumpnjed's Avatar
Default Single Stack Tips and install pics
Im looking to install a single stack on my 96 dodge 12v and was wandering if anyone had any pics of their install and maybe some tips to help with the install. Im looking a kit but cant seem to find one like i want. I wanna put the stack in the corner of the bed on the passenger side. Any tips or pics would greatly be appreciated.
Old Jun 4, 2009 | 12:17 PM
djwhonda92's Avatar
well if you want it in the corner i would recommend gettingit to the location you want it going up before bringing it through the bed... also dont do what i did... i used a small drill bit then cut out the hole... just go buy the size you need of a wholesaw bit
Old Jun 4, 2009 | 08:36 PM
wisconsin redneck's Avatar
u could drill a small hole then use a sawsall the cut out the rest?
Last edited by wisconsin redneck; Jun 4, 2009 at 08:36 PM. Reason: Automerged Doublepost
Old Jun 8, 2009 | 10:24 AM
cumminsman95's Avatar
what i did was cut a hole offset from the center of the bed, and take ur exsiting exhuast and cut it off at the start of the bed. from there get an elbow and run ur pipe threw ur bed then get another pipe and run it to the corner of the bed then just add the stack that u want. its alot cheaper then buyiing a kit.
Old Jun 8, 2009 | 11:24 AM
94 12valve's Avatar
here is what mine looks like
Old Jun 8, 2009 | 11:36 AM
stkdram55's Avatar
mine looks the same as his ^^^ i like it off centered right where the exhaust runs then putting it off to the side of the bed
