Adjusted the APPS
I figured i would see how much the tps was off on voltage today and found that it was reading .344 , which should of read .441 , so pulled everything apart and got it dead on .441.
Figured i would take it for a test drive to only find out that a few codes came up. (one was 500 and the other was a 236)
Do i need to clear these to see if it made any changes? Oh will the 236 stop me from building boost? Cause i am only hitting 18 lbs at WOT.
Hope this helps for the code that you have.
P0236 Turbocharger Boost Pressure Sensor Performance / Rationality
WikiAnswers - What are the 2001 dodge ram cummins diesel error codes
Craigdegolier
Jul 20, 2015 04:46 AM
Mr. Walkway
Dec 11, 2014 10:28 AM
