Idle
Old Jun 3, 2009 | 08:38 AM
wisconsin redneck's Avatar
Default Idle
how do i turn the idle up on my truck? it's at about 800 right now. will turning the idle up help cold starts? I live in wisconsin and last winter it got down to -30 with the windchill.. being in school and all my trucks going to be sitting out in a parking lot away from ny outlits (so no blockheater) ik that its prob not going to start at -30 but its ususally around 10-15* round here. also, when i start the truck and put it into reverse it dies sometimes. but then when it gets hot its fine. is there any other way to improve cold starts?
thanks guys
Old Jun 3, 2009 | 02:42 PM
djwhonda92's Avatar
to turn up your idle you have to reach around behind the afc its about a foot down and if you have someone hit the pedal and you look you'll be able to see where it is roughly. it is a bolt to the left of the acceleration rod... there are two bolts on it and you have to losen both of them and screw the bolt in or out depending on if you want higher or lower rpms...
little advice, do it when the truck is running and have a buddy tell you your idle so you dont have to get in and out
Old Jun 3, 2009 | 04:54 PM
FastCR's Avatar
thanks guys
I was in the same boat in SW MT. Would get 20 below before wind chill and no where to plug in the truck at school. Run good deep cycle batteries and you could put a manual button on your grid heater to run it a little longer. My buddy's dad used to just cycle the ignition 3 times before he started his 12 valve.
Old Jun 3, 2009 | 07:44 PM
alright sounds easy enough... wut would u recomend the idle be at for starting it in the winter? is there nything else i could do to help cold starts? oh what would be a good battery(s) to run during the winter?
Old Jun 3, 2009 | 07:55 PM
94cummins12v's Avatar
with a/c on in the summer it is recomended to be set at 850 in the winter i set mine at 1100
Old Jun 3, 2009 | 09:40 PM
nything else to improve cold starts?
Old Jun 3, 2009 | 11:23 PM
FastCR's Avatar
interstate batteries are the best deep cycles IMO. I have optimas and I'm absolutely un-impressed with them. I wish I had gone with the interstates but I was working at Crapa and could get the optimas for the same price. Get as many CCAs as you can.
Old Jun 4, 2009 | 12:23 AM
dont even get me started on optimas as far as cold starts dont advance your timing. advancing your timing kills your cold start ability
MechanicalDiesel
Aug 11, 2015 08:14 PM
jordanokc
Feb 8, 2015 03:59 PM
Mc Merc
Dec 16, 2014 06:59 AM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
