School me in the spedometer setup
Old Jun 2, 2009 | 03:40 PM
Budgreen's Avatar
Default School me in the spedometer setup
OK, sorry i'm a newb on this stuff but bear with me i'm usually a GM guy
1993 W350 5spd
here's my dilema.
speedometer is 10mph fast across the board, but the odometer clocks correctly.. are they run separate? or off the same signal.. how would i look into fixing this
Old Jun 2, 2009 | 04:20 PM
RSWORDS's Avatar
Should be off the same signal I would think. Not really my area though. Someone should be able to help you though.
Old Jun 3, 2009 | 07:16 AM
cummins_guy's Avatar
they are off the same line, sounds liek you need the gear that goes inside the trans.
look under the truck(driver side of trans) you will see a line that goes to the front of the truck (one round casing, covering the plastic spindle) see if that is loose.
vinnie0104
Jul 6, 2015 03:55 PM
May 15, 2015 12:40 PM
klu408
Apr 26, 2015 07:52 PM
blakec
13
Dec 19, 2014 08:24 PM
