Fuel plate question
Old Jun 1, 2009 | 04:45 PM
BigBadDuallyMan97's Avatar
Default Fuel plate question
If you slide the stock fuel plate forward with no modification to the plate itself do you still have to adjust the governor arm ??
Old Jun 1, 2009 | 05:23 PM
Benjamin's Avatar
Bombardier
if the gov arm goes under the plate. some pumps will need the adjustment some won't. that is why you need to check it every time you make a plate adjustment.
Old Jun 1, 2009 | 07:02 PM
xzaq103's Avatar
FormerVendor
Shouldnt need to be.
Old Jun 1, 2009 | 09:55 PM
relay93's Avatar
After you have made the adjustment and before putting the AFC housing back on, with motor off, while looking below the fuel plate lift up the fuel shutoff solenoid arm with one hand and with the other hand move the throttle linkage, as if adding fuel, and see that the arm does not get hung up under the plate. If the arm does not go under the plate pat attention to where the arm tries to make on the profile on the plate. I set mine to where it hits the very bottom of the plate and not up higher in a deeper part of the profile.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
SMatyac
Nov 15, 2014 07:35 PM
