24 valve on 12 valve
yes it will work you need new injection lines and something needs cut out or off for it to fit but people have done it its not to hard from what ive heard but a stage 2 port job will flow as much air as a 24valve head
yeah it will fit, never heard of having to cut off anything to make it work but it might IDK, im with tater just get a good port and polish and you will have plenty of air...and yes you have to get new injectors and injector lines for this swap to work
yeah or you'll be running into the same problems 12v guys that run the marine 370 sticks. Little more power, more heat, more smoke not really worth it unless your gonna do it all the way the right way
