Boost Leak
Old May 31, 2009 | 07:49 PM
Turbohunter's Avatar
Default Boost Leak
Any one ever run into any boost leaks near the intercooler on the 24 valve. I think i might have one but i cant find it. I am looking for someone to describe the noise to me.
Old May 31, 2009 | 08:18 PM
Whit's Avatar
Site Mascot
tighten all yer hose clamps and get the leak stopped....not hard to do I think its 11mm
Old May 31, 2009 | 09:16 PM
bryson's Avatar
IIRC, the passenger side lower silicone coupler is pretty notorious for cracking/splitting too...
Old May 31, 2009 | 10:33 PM
tearin_it_up_everywhere's Avatar
or the drivers side will rub on teh finder pinch edge also
Old Jun 1, 2009 | 01:12 AM
Uncle Bubba's Avatar
Here is how to find it. https://www.dieselbombers.com/cummin...tructions.html
Old Jun 1, 2009 | 06:07 PM
We went over all the intercooler piping and suck and pressure tested and everything is fine so i am guessing the noise isnt coming from that
Old Jun 1, 2009 | 08:54 PM
Rooster24v's Avatar
its more of a woosh sound than the turbo whistle.. almost like using an air blower hose on an air compressor... thats what mine sounded like.
Old Jun 1, 2009 | 10:55 PM
Did ya go over everything in the system all the way from the exhaust manifold to the the intake heater hitting everything in between with soapy water. That's the only way your gonna know that there is no leaks. Especially check the bottom side of the exhaust manifold and the grid heater, they are the two most common places.
Old Jun 2, 2009 | 04:43 PM
i will check that today thanks. i will post update tonight
find the tinest hole today at the passenger side of the cooler in the boot not even a pin whole it held 20 psi in the sytem while checking for 5 min after 5min it was down to 18 psi. Do you really think that can make such a loud noise. I think it has to be something else. Anywho I am putting a new boot and two new clamps on it tomorrow i guess we will find out. I will post tomorrow
Last edited by Turbohunter; Jun 2, 2009 at 04:43 PM. Reason: Automerged Doublepost
Old Jun 2, 2009 | 05:13 PM
Whit's Avatar
Site Mascot
ya that would do er.......also check all yer turbo boltups...................the heat does funny things there too
