My fuel problem
Old May 31, 2009 | 11:09 AM
torocon's Avatar
Default My fuel problem
Gents,
I have a 1994 2500 2nd Gen with a P7100. Before I bought the truck, the driver was trying to fix a fuel problem by taking the lift pump off, changing the filter and R&R the tank. I rode in the truck daily and one day it would not start. He never got it running and I bought it.
I found out that the solenoid was not lifting when the switch was turned on.
I can manually lift the solenoid and it locks in place.
I can get fuel to the return line on the IP with the prime bulb but not to the injectors.
No one working on this truck are experienced with diesels.
Could the Injector Pump be bad? I am afraid He created problems by taking everything apart.
I cannot get it to start at all.
Any suggestions?
Old May 31, 2009 | 11:37 AM
94 12valve's Avatar
if your getting fuel to the return and not the injectors I would check and make sure the DV's are installed right and that the holders are not restricted.
if there alright I would pop the afc housing off and make sure the rack is moveing when you hit the pedal.
if the rack is moveing freely then you have a plunger/ barrel issue.
Old May 31, 2009 | 12:17 PM
torocon's Avatar
Default dieselly challenged
not sure what a DV or AFC is
Old May 31, 2009 | 02:50 PM
94cummins12v's Avatar
dv is called a delivery valve it is all the barrel looking things on the top of the pump that your injector lines hook to the dv is inside those. the AFR is you Aneloid fuel control were it houses your afc arm and fuel plate
burndiesel
10
Feb 7, 2023 01:15 AM
Dbleo351
Nov 20, 2016 09:34 AM
stevew970
Jeep Liberty
Aug 31, 2015 07:56 AM
moneypitk5
Feb 12, 2015 11:01 AM
Colby cummins
Nov 16, 2014 01:18 PM
