03 6.0 injectors
Old May 30, 2009 | 12:34 PM
brad2003's Avatar
Default 03 6.0 injectors
i have an 03 6.0 with the banks bighoss bundle i keep going through injector and was woundering if i up grade to 75 horse injectors will thise cure my problem. thanks for your input
Old May 30, 2009 | 04:45 PM
mysterync's Avatar
Well Injector Failures wont really be fixed by going to a larger nozzle. It may even make the problem worse. If your having problems with a 6.0 you need to start by looking at the oil change pattern , what oil and so on. BG Products does a oil system flush thats been known to help! What symptoms are you having and we'll be able to help you a little more!
Old May 30, 2009 | 10:46 PM
Big Angry Hillbilly's Avatar
Check your base fuel pressure. Low/negative fuel pressure KILLS 6.0 injectors.
Old Jun 1, 2009 | 11:11 AM
brad2003's Avatar
ok i chainge the oil every 3000 mil i use valvalene oil and chainge the fuel filters every 6000 it dose good for quit a wile then it just blows one. but as far as syptoms it dosnt realy show any.antial after it blowes one.
so if i up my fuel pressure ill have less chances of blowing them. becouse i thought it would make the problem worse.so all i should have to do that is adjust my chip setting.becouse i can up it to 200% with my banks pda.will that help.all the pawer is ther but it just blowes them.
thanks for all the help
Old Jun 2, 2009 | 09:16 PM
Superstroker10's Avatar
if you up the pressure that wont cure the problem.. your running banks tunning? when you say it blows an injector what do you mean.???
i would start with your fuel quality. where are you getting fuel at.. try a different location. change the fuel filter more often even, i dont go more than 5k on mine no matter what.
do you have any gauges or anything. able to at least see fuel pressure or anything of that matter??
Old Jun 3, 2009 | 01:15 PM
brad2003's Avatar
yeah i do with the pda its shows me most of everything but not shure about the fuel i will check if i can wear should the fuel pressure be
Old Jun 3, 2009 | 07:19 PM
CSIPSD's Avatar
There is no way to adjust the "fuel" pressure on your truck without an external fuel pressure regulator. You can add a fuel pressure gauge and get a base line and go from there.
What is failing on your injectors? Who is telling you they are bad and what are they doing? Are they replacing one at a time or did you get a few replaced?
Old Jun 4, 2009 | 12:23 PM
brad2003's Avatar
one at a time its blowing the end off them apart like putting a crack from one side across to the outher on the tip off the nozzle
Old Jun 4, 2009 | 02:10 PM
CSIPSD's Avatar
So you are not really having injector issues as much as nozzle issues... Where do you get your fuel at? How often do you change BOTH filters? Do you run any kind of additive in your fuel?
What most times causes nozzles to break is water... Thats why I ask where you get your fuel and how often you change your filters.
Old Jun 4, 2009 | 04:39 PM
brad2003's Avatar
maverick store and i chainge the fuel filters every 6000 miles.i have never had my water in fuel light come on but i do drain the water drains when i chainge the filters.
o yeah and about every outher tank i add-power service+cetane boost i always chainge both filters together i dont try saving mony when it comes two filters
Powerstrokin7.3
Jun 13, 2015 08:47 PM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
