white smoke/no power
Old May 29, 2009 | 06:30 AM
BAD ASS RAM's Avatar
Default white smoke/no power
alright guys,my dad has a 97 12 valve,stock except for a banks intake manifold.it's been runnin fine until a day or two ago,he said it aint got any power goin up hills.and he said it's blowin white smoke.he said it spits and sputters too.any suggestions?
Old May 29, 2009 | 09:04 AM
94 12valve's Avatar
check timing
Old May 29, 2009 | 10:30 AM
Yup - most likely slipped timing.
White smoke = not enough heat to burn the fuel. Could be the grid heater but its probably too warm for that to be the problem. The problem could also be bad injector(s), worn injector pump, air in the fuel system, and low compression. But check the pump timing first.
Old May 29, 2009 | 11:22 AM
is this something i can do,and if so,how,thanks.
Old May 29, 2009 | 11:45 AM
xzaq103's Avatar
FormerVendor
If you have a timing set and know how then yes if not then no
Old May 29, 2009 | 12:00 PM
Hard for us to answer.
You need a dial indicator, deliver valve socket, magnet, and barring tool:
SP500, Set, Diesel Timing Gauge
You pull #1 delivery valve and measure the amount of lift on the plunger.
If you have to ask - you might need some help
Old May 29, 2009 | 01:00 PM
94 12valve's Avatar
your also goin to need to know what pump he has if its an auto its the 180 if its a stick its the 215
Old May 29, 2009 | 02:25 PM
auto
Timglow546
8
Jun 3, 2015 10:13 PM
shawnecarter
May 11, 2015 02:47 AM
