is this a side effect of 2-stroke?
Old May 28, 2009 | 09:48 PM
steved's Avatar
Default is this a side effect of 2-stroke?
Noticed my cp-3 is seeping, do I remember it can caused by running 2-stroke?
Seems this just started since running 2-stroke...just thinking out loud...
Old May 28, 2009 | 10:54 PM
cashwheel's Avatar
Been running 2-stroke in my 04 since I got it and my 05 since 06 and never any seeping here, must be a fluke.
Old May 29, 2009 | 08:09 AM
XLR8R's Avatar
Lubricant additives shouldn't harm the CP3.
Old May 29, 2009 | 08:18 AM
steved's Avatar
Lubricating the metal to metal parts is one thing, affecting seal material is something else...even biodiesel, which is a great lubricant in ULSD, will negatively affect all the seals in older diesel equipment.
I am pretty sure I read where there were a few guys that experienced a seeping CP3 while using 2-stroke. I was hoping some of the more knowledgeable/experienced crowd would chime in...
As it is, I will be stopping the use of 2-stroke to see if that limits the leak...it seems to be leaking from the case halves and dripping down the block. This CP3 was already replaced many miles ago when it was found leaking from the wiring harness...
Old May 29, 2009 | 08:34 AM
XLR8R's Avatar
Granted - older diesels beware - but the 625 engine in your truck is recommended to run on B95, so a little 2-stroke shouldn't hurt... how much were you adding, anyhow?
Old May 29, 2009 | 08:39 AM
steved's Avatar
Actually, the 5.9L Common rail is only 20% biodiesel...there was a recent discussion about this in regards to Dodge and Cummins recommendations.
I typically run 1 ounce per gallon, sometimes a little more depending on whether I put in 25 gallons or 30 gallons, I just add two bottles (at 15oz each).
Old May 29, 2009 | 10:09 AM
XLR8R's Avatar
Well, your owner's manual should note that a maximum of 5% biodiesel can be used with the Cummins (mine does), and your 2-stroke ratio is less than 1%...
Dyesel67
Feb 25, 2015 01:38 PM
Dec 10, 2014 08:10 AM
Nov 30, 2014 02:10 PM
Oct 13, 2014 08:10 AM
