top(small) turbo question
Old May 28, 2009 | 09:22 PM
Cumminsdieselboy's Avatar
Default top(small) turbo question
I just traded my dad, my phat shaft 62 for his 66 so he could use the 62 for a top turbo.
Well we flipped the manifold upside down, and the compressor housing hits the ATS manifold, and yes i re-clocked the housings. im not sure if im doing something wrong or if we need a spacer.
Also we need plumbing from a HT-60. so far no one wants to help me. i hope i can find someone.
Cody
Old May 29, 2009 | 08:01 AM
XLR8R's Avatar
You need a T3 spacer... if the 62 exhaust housing has a divided volute, the T3 should also have a divider to match.
Old May 29, 2009 | 09:43 PM
where the heck can i find one of those? i am new to the twins...
Old May 29, 2009 | 09:54 PM
sstockton's Avatar
Any issues with running a t3 spacer that is not divided? I know a lot of people do that on the hx35's to wastegate all 6 cylinders.
HT60 will be a hard one to find plumbing for, and you will most likely be building a lot of it yourself. It is a reverse rotation turbo so if the flange on the exhaust housing is a t6 flange, a hot pipe for an HT3b would probably work. And actually, come to think of it, since you're going from a V-band style outlet on your secondary, rotation shouldn't matter as you can clock the hot pipe any direction you need.
I'm still thinking that you will probably have to do most the fab work yourself on the plumbing though.
Here are some good links for places to buy flanges and plumbing components.
ATP TURBO - The Premiere Provider of Turbocharging Components
AGP Turbochargers, Inc.
Dynaflex Chrome Muffler Stacks | Chrome Stacks | Rubber Intake Elbows | Donaldson Mufflers
Source Automotive Performance Diesel - Home
feel free to shoot me a PM if you have any questions.
Sean
Old May 30, 2009 | 02:20 AM
Fishin2Deep4U's Avatar
I also have an ATS manifold and even with a 1/2" spacer, it still hit. No problem with a spacer and the HX35 though.
Go with a thicker spacer or do as I did and get your grind on with the shoulder on the ATS. Since I had already coated the compressor housing, it was the least of 2 evils.
We have T3 and other spacers and twins parts in stock. Give Eric a call if you are looking for anything.
Dave
Old May 30, 2009 | 09:50 AM
XLR8R's Avatar
Sean
Not if the exhaust housing is single volute - on a twin volute, spoolup benefits from a divided flange (superior pressure pulse preservation).
Not sure where you can get one though - we make our own divided T3 flanges.
Old May 30, 2009 | 11:47 AM
sstockton's Avatar
Thats what i wasn't sure of. Thats seems like a logical enough reason.
Sean
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
torg73
May 11, 2015 03:08 AM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
