HELP!!!!!!!!!
Old May 28, 2009 | 08:39 PM
07redsled's Avatar
Default HELP!!!!!!!!!
hey i was driving the 04 dually with the 48 re trans today felt a little shudder in the trans at 25 to 30 mph when i went to pull out onto the road it moved for 5 or 10 feet under its own power then reved free and coasted backwards. i turned the truck off waited a little restarted and put in gear it moved 5 or 10 feet and did the same thing. the trans fluid is full and no leaks and isnt burnt no codes or check lamps. no noises at all sound normal didnt make any noise when it stoped working either. help let me know what yha all think
Old May 28, 2009 | 09:18 PM
DeLuzGN's Avatar
Is it a 4wd? If so, make sure the 4wd shifter wasn't bumped into neutral.
Old May 28, 2009 | 09:21 PM
07redsled's Avatar
its in gear the trans was slipping for awhile now
Old May 28, 2009 | 09:44 PM
noturningback's Avatar
You might try flushing the trans. I have a Duramax with the allison trans. Did the same thing. Also try putting it in drive with the brake on and accelerate. That will push fluid through the lines with some pressure.
My truck would do that in the middle of town at a stop light. I would try to go and it would just kick out of gear like it was in neutral. I then would have to turn off the engine, wait a few seconds and reboot. Ya know I pissed off some people with my truck over that. Oh well, that's why I like my truck
Old May 28, 2009 | 09:53 PM
07redsled's Avatar
it has 1 month old fluid and i can hold it to the floor and it still doesnt move after that first 5 or so feet
Old May 30, 2009 | 08:37 AM
Does your trany have an external filter and an internal filter? My Allison has 2 filters. The only other thing I can think of is maybe you're having some computer probs. But you said there's no dash warning codes Man I don't know, you'll have to let me know how that one comes out. My panel said (TRANSMISSION DISENGAGED)
NO ****!!!!
That was some good info. The dealership didn't even know what that one was.
Old May 31, 2009 | 12:51 PM
07redsled's Avatar
took my trans out all the bands were melted away and the pan was full of metal time for a stick swap
Old May 31, 2009 | 05:46 PM
Sounds like its time for a new Suncoast 48re.
Old May 31, 2009 | 09:07 PM
07redsled's Avatar
suncoast didnt like me so i think im going a different direction
Old Jun 1, 2009 | 01:02 PM
cumminscr's Avatar
goerend
or a 6 speed swap!
