hrvp
Old May 28, 2009 | 10:10 AM
cummins3's Avatar
Default hrvp
best setup to run with a hrvp???
Old May 28, 2009 | 12:02 PM
Uncle Bubba's Avatar
I know it's not what you want to hear but the best set up to run the HRVP with is nothin but stock equipment. The HRVP will add some HP at stock levels but once you add any toys like programers or injectors the HRVP falls on it's face in comparison to the the Normal Pump(Standard Output).
Old May 28, 2009 | 01:01 PM
cummins3's Avatar
there has to be some way to make power with the pump. I mean why else would it have been made. Its the same as the other pumps basically just modified. I dont understand.
Old May 28, 2009 | 02:22 PM
If you do a search for HRVP in this section you will find some great info, way to much for me to just add it all to the post here or I would.
Old May 28, 2009 | 02:26 PM
Red_Rattler's Avatar
High Tech Redneck
Yup, like Bubba said LOTS of info if you search. But you can make power with the pump. But some guys have made more power with a normal SO pump.
Old May 28, 2009 | 02:34 PM
Just out of curiosity, who did ya buy the pump from or is this just a plan for the future.
Old May 28, 2009 | 10:30 PM
cummins3's Avatar
Ive had the pump for a while, and a buddy was getting rid of a truck and it had just been installed about a month and he said he would trade me even my vp44 for his and mine had 100000 miles on it so i figured ya couldn't beat that ya know. I been running 100hp injectors a 40 turbo and air dog 150 with adrenaline, and I recently stacked a smarty on the adrenaline and couldn't feel one bit of difference and I started researching and found out about the timing and the pump wire being tapped.
Old May 28, 2009 | 11:21 PM
Can't complain about a deal like that on a pump. It's not that they won't make power but once you start Chipping your truck for some reason the HRVP holds back the additional power levels that you should be seeing. They aren't bad pumps just deceivingly named.
I don't even pretend to understand the inner workings as to why this is but it has been proven over and over again. Very few of these pumps even sold anymore since the facts became more well known.
Old May 29, 2009 | 01:13 AM
cummins3's Avatar
right, Im pickin up what ur puttin down man. Im gonna see what I can come up with. maybe make some pretty good power, i got some things in mind ill let ya know how things go
Old May 29, 2009 | 07:58 AM
XLR8R's Avatar
I recommend selling the hot rod VP & obtaining an SO - that'll deliver the most volume, instead of pressure. More HP from an SO pump on VP trucks than anything else.
Besides, hot rods & monsters tend to have crappy idles & drivability issues.
