Boost Pressure at 65mph
Old May 28, 2009 | 01:01 AM
2500HeavyDuty's Avatar
Default Boost Pressure at 65mph
what kind of boost pressure are you guys seeing at 65-70 mph.
i get like 1 or 2 psi and that does not seem normal to me at all.
Old May 28, 2009 | 01:08 AM
94cummins12v's Avatar
even know i have a cummins and a bigger turbo im at 12psi at 70 in 5th even with the stock turbo i was at 8 or 9 dont know why a duramax would be any different
Old May 28, 2009 | 01:11 AM
coyropin's Avatar
yeah im a cummins man also and i see about 10-15 psi in 5th gear
my dads d max does the same low or no boost at highway speeds
Last edited by coyropin; May 28, 2009 at 01:13 AM. Reason: forgot to add the dad part
Old May 28, 2009 | 01:12 AM
i know it also depends weather your on flat land or a slight grade but 1 or 2 cant be corect
Old May 28, 2009 | 07:25 AM
Whit's Avatar
Site Mascot
it all depends on the load on the motor.....I see as low as 3 lbs on flat ground doing 65-75 mph
Old May 28, 2009 | 07:34 AM
Jazz's Avatar
Same here on flat ground just cruising no load no wind I see very little boost at 70. Slight grade will give some boost and a good hill I might see 10lbs.
Old May 28, 2009 | 07:48 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i see low boost with no load on flat ground. on a hill with 5th wheel i might see 30. it depends on load on motor
Old May 28, 2009 | 10:44 AM
even goin up a slight grade in the city itl go up to 2psi, but when its on flat land itl be at 1psi.
noticed im getting chit mileage too this tank
Old May 28, 2009 | 11:47 AM
K50's Avatar
K50
Think your turbo's going out? Could it be a waste gate issue or something?
How does your turbo respond otherwise?
Old May 28, 2009 | 01:54 PM
im thinkin theres a leak somewhere, but can some one with a lb7 tell me what kind of boost they make at 65 mph cruising
am i like the only dmax with gauges out here
