Agricultural & Lawn Equipment Discussion of Diesels Used in Agricultural - Tractors , Lawn Mowers , Combines , Ag Equipment , Zero Turns
MORE POWER
Old May 26, 2009 | 04:52 PM
JEFF's Avatar
Default MORE POWER
I HAVE A Mahindra Tractor WITH A BOSCH VE Diesel injection pump WANT TO TURN
UP THE FUEL NEED SOME HELP.
Old May 26, 2009 | 10:46 PM
FastCR's Avatar
you have the same pump as early 12 valve, 89 to 93. The industrial pumps are set up a little differently, but if you just want more fuel, start reading up on the 1st gen cummins. its not too hard and you should be able to use the same basic mods as the trucks.
Old May 27, 2009 | 08:28 AM
Uncle Bubba's Avatar
The same words of caution as on a truck though when you start turnin up the power, be ready to start replacin more parts then you counted on. Particularly on tractors because those motors will turn out lots more power but they are set to protect the weaker parts of the tractors, the PTO and hydraulics could really take a beatin with that new found power and get real expensive real quick.
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
