throttle valve cable
Old May 25, 2009 | 03:44 PM
bowtech's Avatar
Default throttle valve cable
how do you adjust it?
Old May 25, 2009 | 05:29 PM
chevycummins1@yahoo.com's Avatar
what are you trying to adjust??
Old May 25, 2009 | 06:32 PM
bowtech's Avatar
Wat does it do? i was told about it when we were talkin about makin my auto shift better
Old May 25, 2009 | 08:02 PM
Racer9's Avatar
Couldn't find any pics, but it's a square block with a round button on the side, near the throttle linkage. You push the button, and slide the cable. Don't go very far, just a click or two at a time.
Old May 25, 2009 | 10:31 PM
bowtech's Avatar
any one have pics? wat does it do? witch way do you go to do what?
Old May 27, 2009 | 01:23 PM
BigBadDuallyMan97's Avatar
I'm kinda interested to know about this as well ? What does it do and how does it affect the auto shifting ?
Old May 27, 2009 | 05:50 PM
Racer9's Avatar
Basically it's the kickdown or passing gear cable. It allows the trans to shift at the right time. All I can tell you is adjust it a little and try it. Then you'll know if you have to go more, or back the other way.
Old May 27, 2009 | 05:59 PM
I need to do this then , my passing gear wont kick in half the time .
Old May 27, 2009 | 06:47 PM
Benjamin's Avatar
Bombardier
i talked to Dave Goerend of Goerend Transmission Incorporated 3 years ago when i bought my tranny from him. he said when the throttle is at WOT (Wide Open Throttle), AKA pedal to the metal, full tilt boogie, full throttle, etc, the cable should be pulled taught. there is a lever it is connected to on the tranny where the shift linkage is at. with the motor off, the accelerator pedal to the floor (make sure no floor mats are in the way) get under the truck and make sure this lever is tight and can not be moved. have the person inside the cab slowly depress the pedal so you can actually see the cable and lever move.
hope this helps.
RA113024
Mar 13, 2016 07:42 PM
Andyhc1
Mar 16, 2015 12:00 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
1stgenswap
Nov 3, 2014 09:45 PM
