T Case all brokey...again!
Old May 24, 2009 | 05:59 PM
kazairl's Avatar
Default T Case all brokey...again!
And the lesson for today class, is always make sure your constant velocity joints are in good shape otherwise stuff like this happens:
I just found a small crack in the Rear case too so it is going to be next week before it is fixed.
Basically what happened is the CV on the front driveshaft fubared itself and whiped out the case. IT was probably bad all along and was causing my vibrations. I just assumed that it was the rear driveshaft since it wasn't balanced after it was shortened.
Got the rear shaft balanced and went for a little drive to test it. Vibrations still there. Turned around to go home and thats when the little ball on the CV joint tore out the side of its holder. I'll get some pics up of that when I feel like it.
I REALLY REALLY love my life.
Old May 24, 2009 | 06:41 PM
Lil Red Express's Avatar
OOPS hate it when that happens
Old May 24, 2009 | 08:33 PM
yj junker's Avatar
I had my front u joint let go and the shaft hit the ground and tried to come out the back of the case so I know how you feel
Old May 24, 2009 | 08:57 PM
FastCR's Avatar
jb weld. The one on my other truck was in about 6 pieces by the time I sold it.
Old May 25, 2009 | 12:29 AM
94cummins12v's Avatar
been there before on the side of a snowy pass last winter
Old May 25, 2009 | 01:19 AM
kazairl's Avatar
yeah But I just put this t case in about 2 months ago. grrrr it didn't last long.
Old May 25, 2009 | 09:59 AM
K50's Avatar
K50
Yeah that's brutal man!!
Old May 25, 2009 | 10:21 AM
something wasnt tight or aligned correctly then is that the 271 out of a third gen it looks like the one i put in my truck
Old May 25, 2009 | 01:49 PM
kazairl's Avatar
yeah its the 271 I put in in this thread: https://www.dieselbombers.com/cummin...tc-brokey.html
The only thing I can think of is I have a broken tranny mount however the 241 got along with it just fine for however many miles. Didn't find that until I dropped the tranny to install my DD a few months ago. The added width of the 271 may have hit the frame rail and pushed it over and caused a misalignment. However the T case was barely touching so it couldn't have pushed it over that much.
Old May 25, 2009 | 07:10 PM
if the tranny mount is shot then that is mostlickely what happened
