Performance Clutch
Old May 23, 2009 | 06:40 PM
1999 Sport Cummins's Avatar
Default Performance Clutch
my step dads 01... he got his performace clutch put in and it dosent seem to engage all the way... and you have to kill it to put it in reverse.. but he can't remeber the brand or the horses its made for... but any help or suggestions is appreciated
Old May 23, 2009 | 07:18 PM
Check his Hydraulics
Old May 24, 2009 | 09:31 AM
XLR8R's Avatar
Many of the stronger aftermarket clutches (especially dual discs) with higher plate loads need upgraded hydraulics to work properly.
Does he have a South Bend or Valair?
Old May 24, 2009 | 09:44 AM
94cummins12v's Avatar
singles dont, duals do i have a single and its the stock hydros its the biggest single clutch kit valair makes
Old May 24, 2009 | 10:02 AM
XLR8R's Avatar
Singles normally don't - but they can.
Is the topic your truck or step dad's?
If the clutch operation in question is from Valair, just give Dan a call - he's very helpful.
Old May 24, 2009 | 01:22 PM
it my step dads truck but ill run the two brands you told me by him and see if they ring a bell, thanks for the help ill let yall know if we get it to working right
Old May 24, 2009 | 06:12 PM
If you have weak Hydro's even adding just a Single Disc Clutch can make you have to replace them with a new set or upgraded set.
Old May 25, 2009 | 12:11 PM
he siad a south bend sounds familiar... and he said that when they put it in wich was about 6 mounths ago (he just hasnt been driving it hes been useing my moms truck) he put new hydros in it, but he said that upgrading them might fix it
he also said that he replaced his master cylinder and slave cylinder if thats what yall mean by hydros and were can we get some upgraded hydros
Last edited by 1999 Sport Cummins; May 25, 2009 at 12:11 PM. Reason: Automerged Doublepost
Old May 25, 2009 | 01:51 PM
jkidd's Avatar
master/slave cylinders are referred to as hydraulics or hydros
Old May 28, 2009 | 03:50 PM
Hey guys well we got some upgraded hydros and put them on but they didnt fix the problem... if you have any other suggestions they would be greatly appreciated
