need help
Old May 22, 2009 | 11:43 PM
hak's Avatar
hak
Default need help
i just bought a bone stock 1997 one ton cummins with 150,000 miles. im going to pull a 21 ft capri boat. need some help and advice on what i should do to it perfrmance wise. want more power and for it to smoke more. thanks!!
Old May 23, 2009 | 07:10 AM
tpcdrafting's Avatar
More smoke will = more boat washing.
Is it a 5 speed or an auto? This equates to new South Bend clutch or DTT tranny work
What I have done: Start with a set of gauges, air box of your choice, 4" pacbrake, 4" exhaust, Phat Shaft turbo with 4" outlet. Custom ground cam plate (free power), gov. spring kit and timing advanced.
This has put me close to 400 usable towing horsepower. I still have egt problems on the big hills at high elevation, but even having to watch my pyrometer, I'm still passing everything on the road.
Old May 23, 2009 | 11:28 PM
97cummins's Avatar
Need to see if the kdp(killer dowel pin) issue has been dealt with.
Old May 24, 2009 | 10:14 PM
hak's Avatar
hak
whats the KDP issue?
and its an auto, i dont know much about diesels... usually build small block chevys so im gonna need some helo. thanks
Old May 25, 2009 | 07:57 AM
Racer9's Avatar
KDP; Ram Diesel KDP retainer
Get gauges first!!! EGT and trans temp, boost is also good.
Next; CumminsDatabase.com :: Turning Up A P7100 Pump
The auto will only hold 50 or so more hp than stock, so plan on a new TC and VB, and as long as it's out you might as well rebuild it.
Also consider a 4" exhaust system.
