turbo upgrade
Old May 22, 2009 | 09:13 PM
redneckcummins85's Avatar
Default turbo upgrade
im looking at upgrading my turbo and need some advice.. what brand?? size??? i dont really know much bout turbos.. your help is appreciated.
Old May 22, 2009 | 10:39 PM
cummins724's Avatar
What do you do with it? Tow? Race? DD? Sled pull?
Old May 23, 2009 | 12:51 AM
Give me a call tomorrow and we can discuss your options
Old May 23, 2009 | 04:28 PM
i use it for a daily driver but really want to get into racing it every now and then.
Old May 23, 2009 | 07:22 PM
BD Super B or Industrial Injection Phat Shaft 62/14
Old May 23, 2009 | 08:02 PM
cummins724's Avatar
You planning on bigger sticks for racing?
Old May 24, 2009 | 02:20 PM
yes i am eventually... i want to make my way up to stage 4
Old May 24, 2009 | 08:20 PM
cummins724's Avatar
I've tried every turbo configuration available with 62 & 64 compressors [seriously]. I Daily drive, tow 16k-18k#, occasional racing & sled pull. I had a hard time deciding which combo works best for my needs. I've also tried multiple sets of injectors as well. My 2 favorite combos are the 62/71/14 with 125-150hp injectors or the Super B Special with 200hp injectors. Both combos are very streetable & tow incredibly well [not that you care about towing] I ran the 62/71/14 with II Dragon Fly injectors [150hp] & egts were well in check [1400* wot over 100mph] Never seen over 1250* unless over 100mph. I switched to M5's [200hp] & egts were about the same until I got over 3500rpm, then they would skyrocket to 1800*. I switched to the BD Special & my max egts are 1400 @ 100mph. Hope this helps.
Old May 25, 2009 | 03:01 PM
jkidd's Avatar
Jamie how did you like the 62mm and 64mm with 65mm turbine wheel?
Old May 25, 2009 | 06:03 PM
powerup's Avatar
the problem you,l have for stop and go around town is you will loose your instant throttle response since you have a hy35. seems like a guy needs 2 trucks one for racing one for around town. with over 100 hp injectors your mileage falls of , so if these arn,t an issue go for it.. bigger turbos make top end hp. loose bottom end .:
