Need advice
Ok i have a 2000 3500 5spd stock will i need a mitusa pump? Also does anybody have a fix for 5th gear?
Quad boost fooler
edge comp
edge stage 3 injector's
Fass DDR
Quad boost fooler
edge comp
Fass DDR
Here's your fix for the 5th gear nut. NV4500 Parts
I'm a die hard fan of the MITUSA Pump. Think every truck should have one.
Thanks guys does anybody foresee any problems with this setup as of right now all the parts are in the boxes awaiting my return from Iraq to be installed and let me tell you im getting antsy. Also are there any other choices besides the 2inch leveling kit
Like said before, you won't need the Boost Fooler, your Comp will take care of that for you.
What's your goals for the leveling kit. Need to know this to tell ya what options there are for you.
Here is lots of info for the front end leveling the real way instead of the shortcut blocks. https://www.dieselbombers.com/5-9l-2...d-rebuild.html
You also need to get rid of the stock fuel pickup in the tank, fuel lines and banjo bolts to go with bigger lines and high pressure fuel fittings. The stock stuff is to restrictive for high horse power applications.
Its 2wd i just wanna get the nose outa the dirt where can i get a mitusa and im done moddin the engine will still need the big line kit and how hard it it to install?
Also is possible to run two stock turbos is a twin setup is there any gain over one stock
The big line kit is an easy install, just takes some time.
The twin turbos using both the same turbos regardless of what turbos you used would yield very little gains in performance and sure wouldn't get you enough to justify all the expenses and problems you would have to deal with gettin em set up.
