timein at 16?
Old May 21, 2009 | 10:57 PM
bowtech's Avatar
Default timein at 16?
wat does it do for the egt and mpg?
Old May 21, 2009 | 10:58 PM
xzaq103's Avatar
FormerVendor
You gain top end and loose a tiny bit of bottom end power. it ups milage lowers EGTs it also makes it louder and smokes a little more and can make a little bit more idle haze and slightly harder to start on colder days.
Old May 21, 2009 | 10:59 PM
I didnt notice much performance difference in mine. The factory timing slips so it is necessary to retime to make the truck run like its supposed to.
Old May 21, 2009 | 11:03 PM
xzaq103's Avatar
FormerVendor
I guess I should have added that all I really noticed was more noise. and it revs alot easier past 3K but thats when I went to 19.
Old May 22, 2009 | 12:42 AM
94cummins12v's Avatar
i havent really noticed any power gain by having mine at 18.5* mainly responsiveness, cold starts are a b!!ch though
Old May 23, 2009 | 08:08 PM
392hemix's Avatar
whats it cost to get my truck timmed? i would do it myself but don't have the tools and don't really understand how to do it
Old May 24, 2009 | 01:02 AM
Free - $400 depending on who you know, how good they are and where you go.
When doing the timing = its always a good idea to fix the KDP (and vice versa)
Old May 24, 2009 | 03:01 PM
bowtech's Avatar
wat you have to do to set the timing
Old May 24, 2009 | 05:00 PM
pop the gear off and roll the engine so it will advance it, theres a little trick i learned that actually worked with no tools needed. I call it the redneck way, it isnt acurate
Old May 27, 2009 | 07:28 PM
oglejust's Avatar
yeah i know this way but wat do u use to pop the gear off?
