03 to 05 engine swap
Old May 21, 2009 | 10:28 PM
Shootist's Avatar
Default 03 to 05 engine swap
Hey guys looking for a little advice and some help if possible. I have a 2003 F250 6.0L powerstroke with egr cooler problems. In my travels I got my hands on a 2005 6.0L Powerstroke with 25,000 miles on it for the right price. So while this new motor is on the stand I have ordered a head stud kit and an egr delete kit to be installed before it goes in the truck. My question is this. Is there any other mods that I should be considering doing before this motor goes in???? And are there any issues putting an 05 motor in a 03 chassis??? Any help would be great. I've just had this turck a short while and have had a few nightmares but i'm not ready to give up on her. I'm not looking to make a super truck I'm just looking to make my truck dependable and able to pull my camper trailer (9,000lbs). Thanks guys.
Old May 23, 2009 | 01:37 AM
BLACK_06POWERSTROKE's Avatar
if you pull the heads go ahead and get them decked to insure a proper fit.. other than that sounds like you got things under control with the egr delete and the studs. if you get a programmer dont screw around just get an sct with either innovatives or cales tunes.. good luck just checkin you are gonna stay with the 03 turbo right>??
Old May 23, 2009 | 12:58 PM
Superstroker10's Avatar
best bang for your buck is the head studs and egr delete kit.
Old May 25, 2009 | 06:28 PM
Big Angry Hillbilly's Avatar
The ICP on an 03 motor is located at the back of the engine under the turbo; on an 05 it is in the RH valve cover. The intake manifolds are different. The turbos and pedestals are different. The EGR coolers are different, as well as the up-pipes. FICM bracket is different, HPOP cover is different, HPOP is different, Branch tubes, oil rails, and injectors are all different. I'm sure that there's some things I'm forgetting.
I have never seen an 03 EGR cooler fail. The sticker on the motor in the truck, says 2003 on the valve cover?
burndiesel
10
Feb 7, 2023 01:15 AM
boylesjesse
Apr 8, 2015 10:11 PM
DetroitDiesel
Jan 29, 2015 08:13 AM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
Lee Chisholm
Dec 3, 2014 05:58 PM
