Injector question
Old May 19, 2009 | 03:12 PM
DZLSMOKE's Avatar
Default Injector question
For those who have changed out there injectors. How difficult of a job is it? Are there any special tools I would need? I would be changing just the nozzles not the whole injector does that make it a more difficult job? Any help would be greatly appreciated.
Old May 20, 2009 | 08:51 AM
XLR8R's Avatar
The FSM calls for DC's dedicated tool, but you don't need it if you're careful... be sure to pull them straight up, and pay attention to the inch-pound values for the solenoid nuts (pretty easy to break).
Don't forget to follow the correct alignment/torque procedure for the clamp bolts and fitting nuts when setting the bodies against the connector tubes, or you'll have a high-pressure leak that can cause hard starts.
If you haven't swapped them before, I wouldn't recommend doing so without an FSM or someone who successfully has (and X2 for the tips!).
Old May 20, 2009 | 04:11 PM
crazyray's Avatar
its a simple job take your time and pay attention
