tire toe in
Old May 17, 2009 | 02:40 PM
dan33klein's Avatar
Default tire toe in
hey guys, i have a 96 2500 and when i have my brother drive it up the street the front tires look like the top of the tires are toed in bad.
also you can see it a little bit when its just sitting. but when it moves the top looks toed in bad?
what would cause this?
how can i fix it?
Old May 17, 2009 | 04:36 PM
FastCR's Avatar
Camber or tow in?
Looking at the front of the truck:
Looking from the top:
If the camber is bad, jack one wheel up, and push back and forth on the top of the tire, as in push the top of the tire in then pull it out while its off the ground. If it has play, the balljoints are bad.
If the toe in is actually wrong, he needs an alignment. You can do it yourself but its pretty hard.
Old May 17, 2009 | 10:11 PM
dan33klein's Avatar
yeah i was talking about camber.
it has negative.
the top is pointed into the vehicle
i did the ball joint test and they seemed fine i dont get it.
but ill try again tommorow
dallasca
28
May 26, 2015 12:58 AM
salty4life
Apr 12, 2015 08:31 PM
LB7yooper
Chevy/GMC Duramax 01-04 LB7
Mar 23, 2015 11:33 AM
Supremedragonx
Mar 1, 2015 01:50 PM
veggyoilkid
Tire, Wheel & Suspension
Nov 5, 2014 01:34 PM
