auto trans shifting
Old May 17, 2009 | 01:06 PM
Raking79's Avatar
Default auto trans shifting
My 97 is not shitfting correctly and trying to get some information. The tranny fluid is good (checked in N) but the tranny does not shift correctly . When I put the truck in "R" it takes a couple of seconds then jumps into gear. When i put the truck in "D" it will run in 2nd gear for about a mile while driving 35 - 45 mph then it will shift hard into 3rd and on up like normal . I have noticed once the truck is at normal operating temp that the shifting is not as bad. I have read something on the web about the electronic governor would this have something to do with the problem? Where is this located and can I test this on my own or do i have to have a machanic test it ? Thank for the help in advance.
Old May 17, 2009 | 01:32 PM
BigBadDuallyMan97's Avatar
IM NOT A TRANS GURU BUT , MY 97 DID THE SAME THING AND I FOUND A LOOSE LINE GOING TO THE TRANS THAT WAS LEAKING . MY BUDDY HAD THE SAME ISSUE SOME YEARS AGO AND HE DID MENTION TO ME ABOUT THE GOVERNOR THAT HE HAD TO CHANGE OUT . THATS ALL I KNOW BUT ID LET ONE OF THESE CUMMINS GODS ANSWER YOU TO BE SURE .
Old May 17, 2009 | 11:42 PM
Raking79's Avatar
Thanks for the info. I looked all up under the truck but did not see any leaks. I am going to call a trans shop tomorrow just dont want to get ripped off since i know little about auto transmissions.
DieselDan_5.9
Jul 30, 2015 07:05 AM
kydieseltech
May 28, 2015 05:00 AM
apehangerjoe
Mar 26, 2015 03:01 AM
metrickjb
Jan 21, 2015 04:16 AM
countryboy040993
22
Nov 12, 2014 11:25 AM
