12v low to mid rpm stumble
Old May 16, 2009 | 11:33 AM
95ramcummins's Avatar
Default 12v low to mid rpm stumble
it ran great until recently. i have done all the work myself. custom fuel plate, milder than a #10, air box mods, 4" exhaust, and gauges. two days ago it began to stumble at low to mid rpm's. today i changed the air and fuel filters, no change. it smokes black a little, gets worse when the stumble starts but once the stumble clears it cleans right up.its not a hot rod, i just turned it up a little so it was easier to drive. i also tried readjusting the afc, thought maybe the star nut moved. i can crank the star nut way back and it still does it, just no power. 3/4 of the way forward it stumbles the same but runs good. im lost cuz its been running great for months. any ideas on what to check?
Old May 16, 2009 | 11:56 AM
dan33klein's Avatar
could be losing a cylinder because of a bad injector
Old Jun 5, 2009 | 01:44 AM
well i installed new injectors today and they made no improvement. i have noticed a ticking that is getting louder. i check the valve lash today and they are all right on the money. any more ideas as to what the problem might be?
Old Jun 5, 2009 | 01:49 AM
94cummins12v's Avatar
is the ticking loader on the driver side than the passenger side? if it is i have already experianced it, it would be your lift pump craping out
Old Jun 5, 2009 | 02:00 AM
no kinda center of the engine maybe a little to the passenger side. cant hear it at idle only around 1500 rpm or higher.
Zach56238
Sep 3, 2015 06:57 AM
robbyS
Apr 16, 2015 02:22 PM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
dunruh
Nov 27, 2014 07:57 AM
vfizzano
17
Oct 9, 2014 02:26 PM
